Rahm
Mar 31, 2021Tutor
Firm Ware update for N300
I need to update firmware. I cannot do it now with netgear genie. I found that my ISP must perform the update. Just wanted to confirm before I contact them. Am I correct? Is there anything I nee...
- Apr 02, 2021
SUCCESS....I got the firmware updated.
Thank you for your help and patience,
Mar 31, 2021Guru - Experienced User
You have the wnr2000v5?
If so, the isp doesn't update it, you do.
you can get the firmware and the manual that goes over a manual update here:
WNR2000v5 | N300 WiFi Router | NETGEAR Support
Rahm
Mar 31, 2021Tutor
How do I purchase support to help me upgrade firmware?
Thank you
- plemansMar 31, 2021Guru - Experienced User
Don't take this the wrong way but if you truly have a wnr2000v5, its more expensive to buy support than it is to buy a new one.
Its pretty easy to update the firmware.
you can read the guide here:
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
- RahmApr 01, 2021Tutor
I get to step 8 in the instructions:
When I enter the router admin user name and password I get an error message that the server does not support the operation requested by your client. I have tried the default address 192.168.1.1 but that does not work either.
Any ideas how I get around that?
I appreciate your help.
- plemansApr 01, 2021Guru - Experienced User
step 8 is the password/login info for the router.
Does the password/login info screen pull up?
But when you enter the password info, it says not supported?
Did you change the password?
