Rahm
Mar 31, 2021Tutor
Firm Ware update for N300
I need to update firmware. I cannot do it now with netgear genie. I found that my ISP must perform the update. Just wanted to confirm before I contact them. Am I correct? Is there anything I nee...
- Apr 02, 2021
SUCCESS....I got the firmware updated.
Thank you for your help and patience,
Rahm
Mar 31, 2021Tutor
How do I purchase support to help me upgrade firmware?
Thank you
Mar 31, 2021Guru - Experienced User
Don't take this the wrong way but if you truly have a wnr2000v5, its more expensive to buy support than it is to buy a new one.
Its pretty easy to update the firmware.
you can read the guide here:
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
