cyndiman1's avatar
cyndiman1
Follower
Mar 29, 2021
Firm Ware update for R6230
I just got an email stating I need to update the firmware.  It doesn't state what version we should be running.  Any way when I try to run the update through the NightHawk app, I always get the messa...
  • plemans's avatar
    Mar 29, 2021
    If you log into the router through the browser, you can see on the status page what version of firmware you're on.
    You can then compare it to the current release version. It seems like every 6 months (or so), netgear must send out an update notice and we see a bunch of posts on here about update. Half the time,the person is already updated.
    https://www.netgear.com/support/product/R6230.aspx
