PhilKr
Jul 21, 2018Follower
Firm Ware update R8000P
I saw some reviews that indicated that when you updated the firmware, users experienced problems. Since my router is new, it indicates that there is an update available for my router. an agent told m...
- Jul 24, 2018
You should be fine to upgrade the firmware just make sure you do it with a PC directly connect via wired ethernet and not with a device connected via the wireless.
DarrenM
DarrenM
Jul 24, 2018Sr. NETGEAR Moderator
DarrenM
gl-moore
Aug 16, 2018Initiate
Hi,
No matter f I upload firmware or using the auto method the fireware is not updating... once rebooted it shows same version.
| Hardware Version | R8000P |
| Firmware Version | V1.4.0.10_1.2.14 |
| GUI Language Version |
V1.4.1.24_2.1.46.1
- DarrenMAug 20, 2018Sr. NETGEAR Moderator
maybe try the TFTP method see if that works
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
DarrenM
