PhilKr's avatar
PhilKr
Follower
Jul 21, 2018
Firm Ware update R8000P
I saw some reviews that indicated that when you updated the firmware, users experienced problems. Since my router is new, it indicates that there is an update available for my router. an agent told m...
  • DarrenM's avatar
    Jul 24, 2018
    You should be fine to upgrade the firmware just make sure you do it with a PC directly connect via wired ethernet and not with a device connected via the wireless.
    DarrenM
