jserpa
Jun 21, 2018Aspirant
Firmeware upgrade does not coplete
I just attempted to upgrade the firmware in my router, but after 45 minutes, it was still not complete. The power LED is still blkinking.
I tried to power cycle it, but to no avail. It will not...
- Jun 25, 2018
I went out and bought a Linksys to replace the "broken" Netgear.
antinode
Jun 21, 2018Guru
> I tried to power cycle it, but to no avail. It will not boot.
What does the Power LED do now? You may be a candidate for the TFTP
recovery scheme. See, for example:
https://community.netgear.com/t5/x/x/m-p/1533866#M87578
jserpa
Jun 22, 2018Aspirant
The power light is still flashing. I can't use the tftp hack because I cannot access the router at all. It does not boot either the new or the old image. So, I can't http to it. It's not coming up at all.
Thanks for the suggestion though.
