avmoffitt
Apr 17, 2023Aspirant
Firmware & Remote Management Question
Hello, I did a bit of searching but I wasn't able to find out exactly what I needed since most of the previous discussions were already closed. Basically, I am on V1.0.11.136_10.2.120 with my R70...
michaelkenward
Apr 18, 2023Guru - Experienced User
avmoffitt wrote:
Remote Management has changed to Web Services Management and it no longer works like I need it to.
For security reasons, Netgear has disabled the old style of remote management.
Why is the Remote Management feature being removed from NETGEAR routers? | Answer | NETGEAR Support
Anywhere Access does not have the same level of control.
The end goal for me is to be able to log in remotely to my router and enable port forwarding to be able to remote control devices in my house.
No can do.
There may be other tools out there that will let you achieve your goal.
- avmoffittApr 18, 2023Aspirant
michaelkenward thanks for the info. I will take a look at that link. So more or less if I want to have that feature the only thing that I can do is roll back the FW to a previous time when it was there. I feel like this might be a better solution rather than keeping the port forwarding settings on when I am not using them.
- microchip8Apr 18, 2023MasterYou can set up Port Triggering instead of forwarding. Will close ports after a while of no usage.
microchip8 If I do that and need to re-open, I am not able to until I am back at the web console correct? As in, there is no way to re-activate even in the Nighthawk App?
