jall_1821
Dec 17, 2021Initiate
Firmware 1.0.4.122 Potential Issues
I recently upgraded my R6400v2 to firmware version 1.0.4.122 and had since has issues staying connected to the Internet. At first I thought it was an ISP issue, but basically ruled that out after a ...
- Dec 26, 2021
Sorry for the late reply. I was out for a little while. It turns out that it was an ISP issue. It was just such a strange issue that they couldn't detect it. I'm still not entirely sure what it was, but most likely a hardware issue with their equipment, maybe the port itself. The ISP replaced our gateway and that seems to have resolved our issue. Thanks for the assistance!
Dec 17, 2021Guru - Experienced User
I would try 1 move version before the .118 version. The .118 and .120 had dns issues that a lot of people ran into.
Try downgrading 1 more before that and then do a factory reset/reinstall. Disable auto-updates.
jall_1821
Dec 26, 2021Initiate
- plemansDec 26, 2021Guru - Experienced User
Glad that fixed it. you can mark it as solved then.
