95wildtt
Nov 01, 2021Guide
Firmware 1.0.5.38 broke Ethernet ports HELP!
Hi, Just updated my firmware today and none of my ethernet ports (other than WAN) work any longer. Have tried reset, reboot complete network, and no luck... Wifi works fine. Thanks for any a...
- Nov 17, 2021
Hi,
Sorry for not gettiung back to this sooner...
I rolled back to 1.0.5.28 (just picked at random) then disconnedted the power for 5-10 minutes, and the ports worked again.
Then flashed to 1.0.5.38 again and all is well... Not sure where the change happened, or what didn't get set/reset in .38, but rolling back solved it for me.
Thanks for the help,
John
