95wildtt
Nov 01, 2021Guide
Firmware 1.0.5.38 broke Ethernet ports HELP!
Hi, Just updated my firmware today and none of my ethernet ports (other than WAN) work any longer. Have tried reset, reboot complete network, and no luck... Wifi works fine. Thanks for any a...
- Nov 17, 2021
Hi,
Sorry for not gettiung back to this sooner...
I rolled back to 1.0.5.28 (just picked at random) then disconnedted the power for 5-10 minutes, and the ports worked again.
Then flashed to 1.0.5.38 again and all is well... Not sure where the change happened, or what didn't get set/reset in .38, but rolling back solved it for me.
Thanks for the help,
John
Nov 12, 2021Guru - Experienced User
Could you load up Voxels R9000 FW and see if problem is still there?
You can revert back to stock afterwards.
I would open a support ticket if you have not already and let NG know whats happening.
64dude wrote:
Update. I factory reset and rolled back to 1.0.5.36, and ethernet ports still won't function, just flashes. 1.0.5.38 appears to have bricked the ethernet ports permanently. Wifi still works, which for me is useless since I only now use the R9000 as a router and swtich. Thoughts?
Thanks,
64dude
95wildtt
Nov 17, 2021Guide
Hi,
John
- FURRYe38Nov 17, 2021Guru - Experienced User
Just curious, what browser are you using to upload FW to the router?
What PC and OS platform are you using?
- 95wildttNov 17, 2021Guide
Windows 10, Chrome
Ok. I would recommend, next FW update, use a different browser, MS Edge or Firefox. I've seen odd things happen when Chrome is used. I don't personally use Chrome for any FW udpates. I also do a complete power OFF of a router by pulling the power adapter after new FW is loaded then back ON. Usually 1 minute is good.
Hopefully you won't see this problem again.
Enjoy. 📡
