DaBuddah
Apr 09, 2022Aspirant
Firmware 1.0.9.88 R7000 shows duplicate devices
After downloading this firmw5 version I noticed the on the nighthawk app in device manager that there seems to be a lot more devices connected then there actually is. For example I only have my tv con...
- Jul 31, 2022
I finally got a chance to take the network down for a while and was able do a factory reset of the AC1900 R7000. I updated the firmware to 1.0.11.136_10.2.120 from a computer connected to the router via ethernet. So far everything is working. I will post if problems develop.
DaBuddah
Apr 10, 2022Aspirant
I had the router check for new firmware and it said there is nothing new š
I also downloaded a new update for the app but still seeing the same situation. Logged in and out of the app, rebooted the router.... same.
Apr 10, 2022Guru - Experienced User
The auto-update process for the r7000 has never worked that great.
You can manually update through. I'd recommend doing it through a hardwired connection for best results.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- BK77Apr 12, 2022Aspirant
I recently updated my R7000 AC1900 firmware from V1.0.9.64_10.2.88 to V1.0.11.134_10.2.119. It worked for two days and then the wifi connected devices would no longer communicate with each other. The devices were all on the primary network not the guest network. The wifi speed did not make a difference. Also found the router browser interface would not work correctly sometimes. After combing the internet for hours I gave up and I went back to V1.0.9.64_10.2.88. Everything is working well now but I really would like to keep up with the latest firmware. Any help is appreciated.
- FURRYe38Apr 13, 2022Guru - Experienced User
Is Smart Connect enabled?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 or 149 to 161 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many
- BK77Apr 14, 2022Aspirant
FURRYe38 thank you for your response.
A factory reset and setup from scratch has NOT been performed since last FW update. If a factory reset is performed can the router settings be saved before the FW update and then restored after the factory reset?
The internet service provider is Verizon FIOS. The ethernet cable goes from the R7000 into an ethernet port mounted on the wall which I assume is connected to the ONT outside.
Smart Connect IS enabled.
Channels are Auto (2.4Ghz) and 153(5Ghz).
There are twelve other wifi access points in the area.
