Crazyharry
Dec 19, 2019Guide
Firmware changelog says drop support for TimeMachine, what does that mean?
I just noticed there's a new firmware for my router, and I'm glad the auto-update option wasn't working (it was enabled). The changelog says it removes Time Machine support and I'm a bit worried abo...
- Dec 19, 2019
Crazyharry wrote:Does it mean I can't use my NAS anymore as a Time Machine when it's in the network handled by the Netgear router?
Or does it only mean that storage attached to the USB port on the router isn't usable for Time Machine anymore?
Thank you in advance for you answers.
No support for Time Machine on the router is only if you are using the USB flash support for Time Machine backup. The lack of Time Machine support will not effect Time Machine on NAS. NAS is a much better solid solution then using the router IMHO.
microchip8
Dec 19, 2019Master
I'm not sure which one it has an effect on. But NG has removed more than just TimeMachine. They did it to free up space so they can add and sell you Armor to protect your butt from hurr-durr-evil-interwebz. It's the typical money grab from NETGEAR
If you want the previous functionality, stay on a version that still has it. .42 one is highly recommends as it seems to have the least amount of issues. Also disable auto-update of firmware. Given how crappy NG firmware is, the chances are high it will mess up or brick your router
