Mckammer
Mar 20, 2019Tutor
Firmware check error
When I try to update my router firmware, I get a “firmware check error”. I tried rebooting, but I still get the message
- Mar 20, 2019
Was trying to update via the app, but getting an error message. Had to use the directions for manual update and it worked. Still not sure why I got the error on the app, but will do manual updates from now on.
Mar 20, 2019Guru - Experienced User
You didn't put much info like model number. You can do a manual update to the firmware if its strictly a router.
go to https://www.netgear.com/support/default.aspx
put in your model number. It'll have the current firmware version as well as a section with manuals that can walk you through how to manually update the device. Give this a shot.
Mckammer
Mar 20, 2019Tutor
Thanks,it is model R6400 router
- antinodeMar 20, 2019Guru
> When I try to update my router firmware, [...]
"try" _how_, exactly?
> [...] it is model R6400 router
Which one?
> [...] go to https://www.netgear.com/support/default.aspxVisit http://netgear.com/support , put in your (actual) model number,
and look for Downloads. (For older versions, under Firmware and
Software Downloads, look for "View Previous Versions".) Find the
kit(s). Download the kit(s) you want. Read the "Release Notes" file
for instructions. - DarrenMMar 20, 2019Sr. NETGEAR Moderator
Here is a link on how to update the firmware and a link to the latest firmware
https://kb.netgear.com/23960/How-do-I-manually-upgrade-firmware-to-my-NETGEAR-router
https://kb.netgear.com/000060487/R6400-Firmware-Version-1-0-1-46
DarrenM
