Mckammer
Mar 20, 2019Tutor
Firmware check error
When I try to update my router firmware, I get a “firmware check error”. I tried rebooting, but I still get the message
- Mar 20, 2019
Was trying to update via the app, but getting an error message. Had to use the directions for manual update and it worked. Still not sure why I got the error on the app, but will do manual updates from now on.
Mckammer
Mar 20, 2019Tutor
Thanks,it is model R6400 router
antinode
Mar 20, 2019Guru
> When I try to update my router firmware, [...]
"try" _how_, exactly?
> [...] it is model R6400 router
Which one?
> [...] go to https://www.netgear.com/support/default.aspx
Visit http://netgear.com/support , put in your (actual) model number,
and look for Downloads. (For older versions, under Firmware and
Software Downloads, look for "View Previous Versions".) Find the
kit(s). Download the kit(s) you want. Read the "Release Notes" file
for instructions.
