Mckammer
Mar 20, 2019Tutor
Firmware check error
When I try to update my router firmware, I get a “firmware check error”. I tried rebooting, but I still get the message
- Mar 20, 2019
Was trying to update via the app, but getting an error message. Had to use the directions for manual update and it worked. Still not sure why I got the error on the app, but will do manual updates from now on.
DarrenM
Mar 20, 2019Sr. NETGEAR Moderator
Here is a link on how to update the firmware and a link to the latest firmware
https://kb.netgear.com/23960/How-do-I-manually-upgrade-firmware-to-my-NETGEAR-router
https://kb.netgear.com/000060487/R6400-Firmware-Version-1-0-1-46
DarrenM
Mckammer
Mar 20, 2019Tutor
Problem solved. Thanks to all.
- antinodeMar 20, 2019Guru
> Problem solved. [...]
"solved" how?
For the benefit of the next poor slob who stumbles onto this thread
looking for useful information, revealing your (embarrassing/stupid?)
blunder could be helpful.- MckammerMar 20, 2019Tutor
