tdunham
Feb 14, 2020Tutor
Firmware Check Error
I am using the app, and unable to update my firmware. Bought the router new 6 mos ago, and haven't been able to run an update, so I'm still on 1.02.46. Any advice on how to get the update functioning...
labatt
Feb 15, 2020Mentor
Just FYI. The app update process is a good way to soft brick the router. Then have to go through the pain of a tftp process so do not do it.
Best way, is read the user manual and do a manual update which is connect a PC/MAC to the router via Ethernet connection.
microchip8
Feb 15, 2020Master
Updates are always recommended over a wired connection using the WebGUI at http://192.168.1.1 - do not use crappy apps and certainnly no wifi either. Firmware updates are delicate processes. The tiniest interruption and you end up with a bricked router
