evanstome
Oct 06, 2021Initiate
Firmware corrupt - AC1900
Hi. I triggered a firmware update to the router (which is actually R6800 AC1900) which seems to have failed. Symptoms - solid amber light on power indicator. When reset (turn off, hold reset whi...
- Oct 06, 2021
Try recovery mode:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
Also try nmrpflash?
https://github.com/jclehner/nmrpflash
Oct 06, 2021Guru - Experienced User
Try recovery mode:
Also try nmrpflash?
- evanstomeOct 06, 2021Initiate
First indiction is that nmrpflash has worked. Need to run through config of the router, but flashing lights at least. Thanks!
- FURRYe38Oct 06, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
