wolfgangcc's avatar
wolfgangcc
Firmware corrupted on( R9000)
I was performing an automatic (from the web...deeply regret trying that now)  firmware update to 1.0.3.6 and i saw some sort of memmory error in the browser mid update. Lost connectivity to everythin...
  • antinode's avatar
    antinode
    Jan 20, 2018
    > [...] The tftp software seems to connect (i also verified i could put
    > a constant ping from my pc) and begins an "updating Flash" progress
    > bar. It gets to the 50%ish mark then stops. [...]
       This may be typical for that TFTP2.EXE program.  Have you tried the
    Windows command-line TFTP program?
          https://community.netgear.com/t5/x/x/m-p/1480318
