wolfgangcc
Jan 19, 2018Aspirant
Firmware corrupted on( R9000)
I was performing an automatic (from the web...deeply regret trying that now) firmware update to 1.0.3.6 and i saw some sort of memmory error in the browser mid update. Lost connectivity to everythin...
- Jan 20, 2018
> [...] The tftp software seems to connect (i also verified i could put
> a constant ping from my pc) and begins an "updating Flash" progress
> bar. It gets to the 50%ish mark then stops. [...]
This may be typical for that TFTP2.EXE program. Have you tried the
Windows command-line TFTP program?
https://community.netgear.com/t5/x/x/m-p/1480318
wolfgangcc
Jan 20, 2018Aspirant
Steps i took..
1. performed a long reset aka 30-30-30 rest
2. left router offline; only connected to my pc with the pc static to 192.168.1.5 in order to connect to the router.
3. opened up TFTP2.exe to push the firmware.
4. selected localy downloaded old firmware version 1.0.2.52 set server to 192.168.1.1 and entered default router password "password".
The tftp software seems to connect (i also verified i could put a constant ping from my pc) and begins an "updating Flash" progress bar. It gets to the 50%ish mark then stops. I have it set to re-attempt 5 times. The counter goes up to attempt number 2 and the new progress bar says erasing flash, it never shows any progress and times out after about 30sec. This repeats unitll it hits the 5th attempt. All during which I have a blinking white power light.
Thanks for the input.
antinode
Jan 20, 2018Guru
- wolfgangccJan 20, 2018Aspirant
The solution was to run things from the command line. Once i turned TFTP and ran it on win 10 everything went smooth!
- antinodeJan 20, 2018Guru
Thanks for the update. Glad to hear that you got it working.
Do you think that Netgear might ever figure out what the problem is
with that tftp2.exe program, or else stop recommending it? (Too much
invested in those "Upgrade Firmware" screenshots?)
