halapplehome
Oct 20, 2023Tutor
Firmware download fails
I login to router login .net, I click “firmware update available” and after 5-10 minutes I get “error 404 unable to find product” Router runs slow, (100 instead of 600 on 5g) and Spectrum confirms th...
- Oct 21, 2023
wow you're on some old firmware.
29 ish versions behind.
Try manually updating.
How do I manually update the firmware on my NETGEAR router? - NETGEAR Support
And for sure do a factory reset afterwards. There was a ton of changes in those versions.
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
microchip8
Oct 20, 2023Master
Which router model?
