halapplehome
Oct 20, 2023Tutor
Firmware download fails
I login to router login .net, I click “firmware update available” and after 5-10 minutes I get “error 404 unable to find product” Router runs slow, (100 instead of 600 on 5g) and Spectrum confirms th...
- Oct 21, 2023
wow you're on some old firmware.
29 ish versions behind.
Try manually updating.
How do I manually update the firmware on my NETGEAR router? - NETGEAR Support
And for sure do a factory reset afterwards. There was a ton of changes in those versions.
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
halapplehome
Oct 21, 2023Tutor
My router is a Nighthawk R7000, AC1900 Smart WifFi Router.
"genie" admin screen (Image attached) "Firmware upgrade available" but when I click on that--the perpetual spinning icon appears for 10-15 minutes then "404 error" pops up.
I have 11 items supported by router. (3 are Canary cameras). When I add more cameras, they fall of the wifi. Nighthawk states up to 30 devices are supported.
Assume two sub-issues are related to outdated firmware?
- Cameras "falling off" wifi, I assume firmware issue
- Spectrum states my speeds should easily exceed 300, even up to 600 on 5G. I'm at about 100. I assume firmware issue,
Many thanks to anyone who might advise. Hal
Oct 21, 2023Guru - Experienced User
- halapplehomeOct 28, 2023Tutor
Thanks for the input! I manually loaded firmware, after I was unable to automatically download it. Probably my older version of Safari and MacOS system. I was told by someone to buy a new router but that was not necessary. Thanks!
- plemansOct 31, 2023Guru - Experienced User
Glad it worked!
