tbarrient
Oct 02, 2019Aspirant
Firmware download has broken link. Cannot get download
Long story short, I had a failed Factory Reset. router lights up but there is no internet connection so cannot log into the router. Want to try this solution: https://kb.netgear.com/000059633/...
- Oct 02, 2019
thank you. This seems workable. I didn't know it was built into Windows 10. Thanks
myersw
Oct 02, 2019Master
Firmware can be found at
https://www.netgear.com/support/
Put in your router model and you well be taken to a location where the firmware is as well another very important document, the user manual.
tbarrient
thanks Bill, for clairification, I can access the firmware, what I am not able to download is the TFTP client I need to update the firmware.
