tbarrient
Oct 02, 2019Aspirant
Firmware download has broken link. Cannot get download
Long story short, I had a failed Factory Reset. router lights up but there is no internet connection so cannot log into the router. Want to try this solution: https://kb.netgear.com/000059633/...
- Oct 02, 2019
thank you. This seems workable. I didn't know it was built into Windows 10. Thanks
Oct 02, 2019Guru - Experienced User
If you're using windows, it has a built in client that you enable.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
tbarrient
