Atlo45
Jun 26, 2021Aspirant
Firmware error update
Hello I would like to know if you can solve me a doubt, I have the firmware update error. I tried to install the firmware via tftp but I could not, I need someone to help me.
michaelkenward
Jun 27, 2021Guru - Experienced User
What error is that? What do the LEDs on your ageing (2013) router look like?
In particular tell us what the power LED shows.
Atlo45 wrote:
I tried to install the firmware via tftp but I could not....
What happened when you tried?
Hard to say much more with so little information from you.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This also explains how to enable TFTP on a Windows PC.
TFTP isn't the easiest operation, so if you are forced to use it try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same.
Atlo45
Jun 27, 2021Aspirant
Well, I am going to try to explain it.
I try to update the firmware inside the router system settings, I get this error "Incorrect firmware file. Get the firmware file again and make sure it is the correct one for this product" I also downloaded it and tried to do it manually also did not work. The firmware version I need to update is "Firmware version 1.0.0.34 (https://www.netgear.com/support/product/WNR2500.aspx#download) "
Now I was trying with tftp but I didn't get it, I followed all the steps shown on this page but I don't know what I'm doing wrong. https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
michaelkenward wrote:
Atlo45 wrote:Hello I would like to know if you can solve me a doubt, I have the firmware update error.
Atlo45 wrote:I tried to install the firmware via tftp but I could not....
Atlo45 wrote:I need someone to help me.
For example:
Well I've been trying almost everything for a week now but well, I don't think I can update it.
- antinodeJun 27, 2021Guru
> Well I've been trying almost everything for a week now [...]
Think, for a moment, about how little useful information that
non-description conveys to the non-psychics in your audience.> [...] I get this error "Incorrect firmware file. [...]
Ok. _Which_ file is the "Incorrect firmware file"? Has it a name?
> Model: WNR2500|N450 Wireless Router
A firmware image file for that model should be something like
"WNR2500-V1.0.0.34NA.img". With my weak psychic powers, I can't see
which file you're actually trying to load into the router.> Now I was trying with tftp but I didn't get it, [...]
"trying" or "didn't get it" is not a useful description of anything.
None of that is a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.Trying to use TFTP to force an "Incorrect firmware file" into the
thing is almost certainly a very bad idea.> [...] I don't think I can update it.
From your "descriptions", I can't tell what you did, which makes it
hard to offer much specific advice.
