Greghatingpcs's avatar
Dec 22, 2020
Firmware fail
My router quit after a power failure and I can't get it working again. I followed the Netgear tftp instructions and i get a "connect request failed" message. Also, when I turn it back on with the reset button held, the instructions say it should start flashing the power light but that never happens. It also doesn't say exactly where to connect the cable on the router. To the internet connection or to one of the numbered connections. I've tried both with the same results. Am I missing something? Thanks in advance, Greg
  • > My router quit after a power failure and I can't get it working again.
       "quit" or "can't" is not a useful problem description.  It does not
    say what your router does.  It does not say what you did.  It does not
    say what happened when you did it.  As usual, showing actual actions
    (commands) with their actual results (error messages, LED indicators,
    ...) can be more helpful than vague descriptions or interpretations.
    > [...] I followed the Netgear tftp instructions [...]
       _Which_ "the Netgear tftp instructions"?
    > [...] It also doesn't say exactly where to connect the cable on the
    > router. [...]
       "It"?  Any of the LAN Ethernet ports should work.
    > [...] Am I missing something? [...]
       A clear description of what your router does, what you did, and what
    happened when you did it?
    • Greghatingpcs's avatar
      Greghatingpcs
      My router powers up but I cannot see any WiFi signals, nor do the LAN ports work. If I plug the LAN cable directly into my laptop, i get connectivety, but not through the router. The amber power on light comes on solid as do the WiFi lights. The internet light comes on half strength and fluctuates. I followed Netgears instructions on TFTP firmware upload and get a "connect request failed" after entering the put command. Also, following the Netgear instructions, they say the power LED should flash after holding the reset button and powering the router back up. Mine does not flash, ever. I hope that answers your questions, sorry for not making myself clear.
      • antinode's avatar
        antinode
        Guru
        > [...] I followed Netgears instructions on TFTP firmware upload [...]
           _Which_ "Netgears instructions"?  Where, exactly, did you find these
        "Netgears instructions"?  (Hint: "On the Netgear web site" is not a
        useful answer.)  Better yet, what, exactly, did you do?  Copy+paste is
        your friend.
           The TFTP recovery scheme is a multi-step procedure which offers
        multiple opportunities for user input, hence user error.  By itself,
        saying that you "followed [some] instructions [or other]" doesn't say
        much.  Almost everyone believes that he's doing the right things.  Not
        every one of them is correct.
        > [...] Mine does not flash, ever. [...]
           I know nothing, but from what I've read here, not all models/firmware
        versions flash.  But an amber Power indicator is suggestive.
