stefaanbolle
Dec 19, 2017Guide
Firmware is invalid.
I cannot upload a new firmware or perform a web update. I always receive Firmware is invalid (update via Genie) or This firmware file is incorrect! Please get the firmware file again and make sure i...
- Dec 24, 2017
Hi,
A TFTP firmware upgrade did the trick. I did not succeed with the instructions posted in your link to the Netgear kb, however I googled somewhat and found below tool which did the trick.
Thanks!
Netgerar firware recovery tool (all credits go to the creator!): https://github.com/jclehner/nmrpflash/releases
antinode
Dec 19, 2017Guru
"I cannot" is not a useful useful problem description. It does not
say what you did. As usual, showing actual actions with their actual
results (error messages, ...) can be more helpful than vague
descriptions or interpretations.
> [...] This firmware file is incorrect! [...]
What, exactly, did you download? Which "This firmware file" are you
specifying? Did you read the "Release Notes" which are provided with
the firmware kit?
stefaanbolle
Dec 20, 2017Guide
I just want to update my running firmware (V1.0.9.12_1.2.23) to the latest version (1.0.9.18_1.2.27) on my R7000. Quite a simple process normally and I have a lot of experience with routers and networks.
However when updating by downloading the file from netgear and uploading it via the router update firmware screen I always receive the error This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product. Also with any other firmware version for the R7000.
When trying to update via the link "A router firmware upgrade is available" I always get Firmware is Invalid
I tried updating the router via Win10 and MAcbook systems with all available browsers on the market. I also performed factory restes before trying the update, but all resulting in above errors.
So why is the router refusing the firmware that it self downloads or that you upload via a downloaded version from Netgear servers.
My first thought was browser incompatibility, but I tried them all (all latest versions of the browsers mentioned above)
- antinodeDec 20, 2017Guru
> the firmware kit?
All still mysteries. These files have names, and "the file from
netgear" conveys no useful information.
> [...] why is the router refusing the firmware that it self downloads
Also still a mystery, but that may be because I still have no idea
what you downloaded, or what you're trying to load into the router, or
whether you're following the instructions which come in the firmware
kit.
> My first thought was browser incompatibility, [...]
Browser incompatibility is unlikely to be the problem.- stefaanbolleDec 20, 2017Guide
I downoaded http://www.downloads.netgear.com/files/GDC/R7000/R7000-V1.0.9.18_1.2.27.zip and also some versions before.
Unzipped the file and uploaded the chk file from the zip. Not much rocket science in here.
Read the release notes, pretty simple and easy read.
Really, I know how to download firmwares, unzip them, update routers (even many other brands than Netgear),...
Please skip these steps in the troubleshooting.
I am looking for someone who can give a clue why every firmware chk file from the Netgerar R7000 downloads gives above errors. I yesterday also tried with a factory-to-dd-wrt image, resulting in the same problem. The Genie web page accepts no firmware file, not even the one it downloads itself.
> [...] Unzipped the file and uploaded the chk file from the zip. [...]
It's normally hard to get a corrupt file (without a complaint) from a
zip archive, and even harder from multiple zip archives. If the router
rejects Netgear firmware files and third-party firmware files, then it
seems more likely that the router's little brain has been scrambled than
that all the firmware files in the world are corrupt.
If the web-interface load procedure fails, then you might try using
the (last-ditch) TFTP scheme, which might take a different enough path
through the software to give a different result. It's also possible
that the router has a hardware problem (bad NVRAM). I've never triedit, so I know nothing, but:
https://kb.netgear.com/22688/
> Really, I know how to [...]
Apparently so. Now.
Few people who post questions here begin with anything like, "I made
the following errors..." Assuming (without evidence) that anyone
actually knows anything usually leads to much wasted time. In contrast,
providing accurate, detailed information normally saves everyone's time
and effort.
Why did you decide to do this update? Actual problem, general
principle, ...?
