stefaanbolle
Dec 19, 2017Guide
Firmware is invalid.
I cannot upload a new firmware or perform a web update. I always receive Firmware is invalid (update via Genie) or This firmware file is incorrect! Please get the firmware file again and make sure i...
- Dec 24, 2017
Hi,
A TFTP firmware upgrade did the trick. I did not succeed with the instructions posted in your link to the Netgear kb, however I googled somewhat and found below tool which did the trick.
Thanks!
Netgerar firware recovery tool (all credits go to the creator!): https://github.com/jclehner/nmrpflash/releases
antinode
Dec 20, 2017Guru
> [...] Unzipped the file and uploaded the chk file from the zip. [...]
It's normally hard to get a corrupt file (without a complaint) from a
zip archive, and even harder from multiple zip archives. If the router
rejects Netgear firmware files and third-party firmware files, then it
seems more likely that the router's little brain has been scrambled than
that all the firmware files in the world are corrupt.
If the web-interface load procedure fails, then you might try using
the (last-ditch) TFTP scheme, which might take a different enough path
through the software to give a different result. It's also possible
that the router has a hardware problem (bad NVRAM). I've never tried
it, so I know nothing, but:
https://kb.netgear.com/22688/
> Really, I know how to [...]
Apparently so. Now.
Few people who post questions here begin with anything like, "I made
the following errors..." Assuming (without evidence) that anyone
actually knows anything usually leads to much wasted time. In contrast,
providing accurate, detailed information normally saves everyone's time
and effort.
Why did you decide to do this update? Actual problem, general
principle, ...?
stefaanbolle
Dec 20, 2017Guide
Thanks!
I always update to the latest ersion, especially if mentioned security fixes.
I will try the tftp path tonight
- stefaanbolleDec 24, 2017Guide
Hi,
Thanks!
