RealDogfart's avatar
Aug 17, 2017
Firmware Suggestion
It would be useful, at least to me, to be able to export the Access Control list as a table. To have an "editable" list of equipment with corresponding IP addresses and their MAC addresses would be useful.
  • > To have an "editable" list of equipment with corresponding IP
       Copy+paste from the Web page?  Have you looked at the ".cfg" file
    produced by (on my D7000) ADVANCED > Administration > Backup Settings:
    Backup Settings?  Perhaps you can extract what you want from that file
    (unsightly as it may be).
    • RealDogfart's avatar
      RealDogfart
      Guide
      Copy and paste the web page - Duh... simple and perfect. Thanks. I had PDF'd a screenshot and was trying to get Acrobat to OCR it into something editable. Talk about the long way. It would only OCR about 90% and the rest was junk. Thanks.
      • antinode's avatar
        antinode
        Guru
        > Copy and paste the web page [...]
           Or, if using a browser is ok, then save the HTML, and try to extract
        the useful data from that.  Perhaps Wget could be persuaded to fetch the
        page, if you can get it past the authentication.  Some scripting would
        be needed to extract the useful data, no doubt.  But, for a one-timer,
        copy+paste can be pretty handy.
           As usual, many things are possible, and there's seldom only one
        solution to a problem in this neighborhood.
