wvboomer
Sep 26, 2018Aspirant
Firmware Update 1.3.1.44 Deleted account information
I was finally able to update my NightHawk router to Firmware Update 1.3.1.44, using my computer, not my mobile device. With mobile device, I was never able to reboot the router. Now that I was able t...
- Sep 26, 2018BoomerModel: R7000|AC1900 Smart WIFI RouterBelieve you are referring to the R7000PWhen you perform a FW update, regardless of the method, Auto Check and Update, Genie for windows, Genie for iOS / Android or manual update, the upload triggers a restart after the FW is upgraded. There is no required step for you to restart the router. A restart occurs as part of the upgrade. If the upgrade were to fail, this would leave the router in a unstable and likely non/semi functioning state. The router would remain in a unstable condition until it was restarted and may still required further intervention to operate normally again. I'd say this happened in your case. I recommend that you reset your device and reconfigure. If you notice any abnormal behavior, I would perform the manual FW update (completely safe to flash the same version over itself) again and reset.The important part to take away here is the method to employ for update. Manual update from a computer connected via ethernet is the safest and most reliable way to upgrade FW. Seems you have figured this out on your own. Upgrades should be planned and performed on your terms.Your experience attempting to upgrade via a mobile device demonstarates wh yemploying manual updates is best.Armor? Don't bother. Not worth it.
wvboomer
You are right, it is an R7000P. They just don't offer the option of selecting the correct router. As to the FW update, it took hold, but I contacted Netgear Technical support, even though their 90 day warranty was up. I figured the lost account information, shouldn't be a part of a 90 day issue. Come to find out, they are transferring account information to a new system or some such thing and mine got caught in the crossfire. They are expected to correct this, but I was told unless I spend $89-299 for their technical support, I won't get anymore 'complimentary' support. Not too impressed by their way of handling these issues.
However, I do appreciate your response and timeliness of it. Thanks again!
shadowsports
Sep 26, 2018Hero
Appreciate your feedback and am glad to hear you might get your trial re-instated. Thank You again!
