Kindon's avatar
Kindon
Firmware update corrupted router.
So I'm trying to force the firmware onto the router to fix this but I'm having an issue figuring out how to establish a connection to the router. I've set up a static ip but keep getting an error whe...
  • Kindon's avatar
    Kindon
    Jan 10, 2021
    Haha wow thank you so much that video answered my question. My router is one that you didn't hold the reset on when it turned on to fix it. You're the best! Just saved me 150 bucks!
