bjtjaden
Jul 20, 2019Aspirant
Firmware update failed - router not working now
I attempted to upgrade our Nighthawk R7000P router firmware to version 1.3.1.64 but the upgrade failed. Now the router doesn’t work and the power led light is blinking Amber. What can I do to fix the ...
- Jul 21, 2019
Router now working. My mistake - in the TFTP command I was using 192.168.1.10 instead of 192.1668.1.1. Many thanks to all for your expert assistance!
antinode
Jul 20, 2019Guru
> [...] the power led light is blinking Amber. [...]
You may be a candidate for the TFTP recovery scheme. See, for
example:
