bjtjaden's avatar
bjtjaden
Firmware update failed - router not working now
I attempted to upgrade our Nighthawk R7000P router firmware to version 1.3.1.64 but the upgrade failed. Now the router doesn’t work and the power led light is blinking Amber. What can I do to fix the ...
  • bjtjaden's avatar
    bjtjaden
    Jul 21, 2019
    Router now working.  My mistake - in the TFTP command I was using 192.168.1.10 instead of 192.1668.1.1.  Many thanks to all for your expert assistance!
