Justme4161
Jul 28, 2021Aspirant
Firmware update failed, Ethernet port is not functional
Last night I attempted to update the firmware on the router. There was a problem with the update. Now I cannot connect to the internet as the ethernet ports are not functioning. I can con...
- Jul 29, 2021
I completed a factory reset earlier today. When I did that there was no change to the LEDs. Also connecting something to those ports does not change the status of the LEDs. I have come to the conclusion, it is a HW issue.
Justme4161
Jul 29, 2021Aspirant
There is no connection to the Internet and site to "loop back" from.
I realized I was not able to find the router address 192.168.1.1 because I was connected via ethernet directly to my modem and wifi to the router. My computer was looking via the ethernet connection for the ip address and ended up on a Netgear webpage saying couldn't connect to router.
Meanwhile, I still have a problem with the router. The LEDs are as shown in the attached photo. There is nothing connected to ports 1-4 so the LEDs should be off. Yet as you can see from the photo, they are as follows, White, Blinking Orange, White and Off.
antinode
Jul 29, 2021Guru
> [...] I was connected via ethernet directly to my modem and wifi to
> the router. [...]
It's tough to test the router's LAN Ethernet ports that way.
> [...] There is nothing connected to ports 1-4 so the LEDs should be
> off. [...]
True. And if you (really) connect a computer to any of them?
If the port-status LEDs don't agree with reality, then I'd guess that
the firmware's corrupt, or the settings are corrupt, or the hardware is
bad. If you've done a firmware update, then the firmware should be
good. A settings reset should straighten out any kinks in the settings.
- Justme4161Jul 29, 2021Aspirant
