beastwood's avatar
Jan 12, 2021
Firmware update failed R7900P
A few days ago I tried to update the router with the new firmware (1.4.1.68), I don't remember my previous version. The update failed and while everything seemed ok at first (network traffic didn't appear to be affected). I couldn't connect to the router using either the app or the IP on a desktop.  Now 3 days later, everything has gotten progressively worse and now it will only connect to websites sometimes, but will usually time out.
I tried to reinstall the firmware update following these instructions:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Two things were different than the instructions.  When holding down the reset button, after turning the router back on, it seemed to take quite a while (2 minutes?) for the button to start blinking and it turned white first, then started blinking. Second, I used the local area connection that was plugged into the router instead of the "Ethernet" connection.
However, when trying to load via the tftp it would only return "Connect request failed"
Anyone have any thoughts? Questions?
  • beastwood wrote:
    When I try and access the router UI through either the app or the website it will just sit and spin and never load the UI, even after trying the reset.
    There is no "website" as most people understand it. It is local stuff that goes nowhere near the Internet. The address is simply a way into the GUI. The failure to get into it is usually a sign of something amiss at your end.
    Here is one pointer:
    If you cannot login to your router | Answer | NETGEAR Support
    It might help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
  • michaelkenward's avatar
    michaelkenward
    From this description, your router is not bust enough to warrant the use of TFTP. Going down that road could do irreparable damage. I hope it hasn't happened already.
    If the router works at all, then it should accept new firmware in the usual way.
    I would stop playing with TFTP immediately. Try some more conventional, and less dangerous tweaks first.
    Did you reset the router to factory settings after the firmware flash?
    New firmware sometimes introduces changes that are not compatible with the old configuration.
    So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
    You can reduce the hassle of reconfiguring all those settings by creating a backup of your settings before you reset. Then if something is still broken after the reset, and the new firmware has not fixed it, you can restore the device to its pre-reset state.
    You could even try restoring the settings even if the new firmware has fixed the problems, but be prepared for the restore to also bring back your problems.
    • beastwood's avatar
      beastwood
      Tutor
      I actually tried to reset it first, using the method on this page:
      https://kb.netgear.com/27486/R7900-FAQs
      Any other suggestions? I'm at a loss.
        michaelkenward
  • Try deleting all browser cache (or using a browser you never normally use). Sometimes saved data for pages gets corrupted, causing issues.
    I just updated my R7900P to v1.4.1.68. I was behind at least 2 versions. I used the router's internal update process. Everything worked perfectly and all settings were preserved.
