BabyDar
May 23, 2021Aspirant
Firmware Update Failure Nighthawk AC1900 R6900
I have been unable to update the firmware today. Signing in to the network going to ADVANCED > ADMINISTRATION > ROUTER UPDATE it says I'm currently at 1.0.1.26 and should be at 1.0.2.16_10. I click...
michaelkenward
May 24, 2021Guru - Experienced User
Good luck.
There are also times when Netgear advises a reset and/or reboot before the upgrade.
BabyDar
May 24, 2021Aspirant
Do you mean that little hole on the back of the router? Would that reset my password?
- michaelkenwardMay 24, 2021Guru - Experienced User
Yes.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Return the Router to Its Factory Default Settings.
