Janosh
Mar 31, 2018Guide
Firmware update file not found
I try to download latest firmware version 1.0.0.124. Following the link, the message "File not found" appears. What to do?
- Apr 03, 2018
Firmware Version 1.0.0.124 is nog available,
michaelkenward
Mar 31, 2018Guru - Experienced User
If you have the R7500v2 described in your footer, that is not the right firmware.
That should be Firmware Version 1.0.3.26. There has never been a 1.0.0.124.
There is firmware and a manual for the R7500v2 somewhere at the end of this link:
>>>> Nighthawk R7500v2 | AC2350 Smart WiFi Router | NETGEAR Support <<<<
If that isn't your device, look at the label on the back and check the model number.
Janosh
Mar 31, 2018Guide
I am sorry, my type is R7500.
- michaelkenwardMar 31, 2018Guru - Experienced User
There is a manual and stuff for the R7500 somewhere at the end of this link:
>> Click here >> R7500 | Product | Support | NETGEAR << Click here <<
- JanoshMar 31, 2018Guide
Of you follow your link and try to download the update file, the message “ File not found” appears. That was the reason I started thuis toppic......
You didn't help yourself by starting this topic with the wrong model number.
These people got it right:
R7500 Firmware Version 1.0.0.124 not found - NETGEAR Communities
A search of the forum before you asked your question might have got you a quicker answer.
