WhoDatSaint
Apr 08, 2021Tutor
Firmware Update for R6400
Trying to update the firmware on the router. I’ve tried via the app and trough router login.net. I get Unable to download GUI language file from Netgear server. I’ve tried downloading the firmware fro...
Apr 09, 2021Guru - Experienced User
You have the R6400? What version of it?
What device are you using to extract the file?
What web browser are you using?
I just tried on v1 and v2 off the firmware for it and was able to download/extract them both.
- WhoDatSaintApr 09, 2021TutorV1,
Windows 10
Tried using internet explorer, Firefox, chrome, and edge browsers
Using a free file unzip program. Think it’s called unzipper. Can you recommend a better one.
Anything would be greatly appreciated- antinodeApr 09, 2021Guru
> Model: R6400|AC1750 Smart WiFi Router
Is that accurate? R6400[v1] or R6400v2? Look for "Model" on the
product label. Current firmware version?> [...] I get Unable to download GUI language file from Netgear server.
> [...]"get" _how_? When you do _what_, exactly?
> [...] I've tried downloading the firmware from the website [...]
Which file, exactly, did you download?
> [...] and unzip the file there's nothing there.
You determined this _how_, exactly? "nothing", or not what you
expected, or what, exactly? An empty firmware kit is extremely
unlikely.
> [...] Anyone have any recommendationsSure. Provide enough actual information that a reader who can't see
what you have, or what you did, or what happened when you did it, might
be able to understand all those things?
Possibly relevant:https://community.netgear.com/t5/x/x/m-p/2060035
> Tried using [...]Really shouldn't matter much. What you actually did with any
browser, and what happened when you did it, would be interesting."Tried" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.> Using a free file unzip program. [...]
Again, practically any unzip program should be able to extract the
files from a Netgear router firmware kit. Including the File Explorer's
built-in "Extract all..." feature.As for "Using", see "not a useful problem description [...]", above.
- WhoDatSaintApr 10, 2021Tutor
product label. Current firmware version?___________________________
Model # R6400
Current Firmware Version: 1.0.0.24
Trying to update to Version:1.0.1.62_1.0.41
____________________________________________________
When I access routerlogin.net and select the option there to update firmware this is when I get the message that says Unable to download GUI language file from Netgear server.
I have accessed routerlogin.net from multiple locations. I have logged in on my laptop which is running Windows 10(have used Microsoft Edge, Internet Explorer, Firefox, and Chrome browsers). I have also logged in on my Iphone using Safari Browser. I used the Nighthawk app and it stated an firmware udpate was available and directed me to routerlogin.net in my Safari Browser. Same error message from all of these.
I went to netgears website under support for the R6400 V1(which is the one I have) and clicked on the firmware link under the support section for this device. It downloaded a zip file to my laptop.
unlikely._______________________________
Once I unzipped the file I went back to routerlogin.net and went through the steps to manually updated the firmware. When i did so it gave me a message that the file inside was .CHK. When i look in that folder I see the Firmware notes and the .cHK fill which apparently is not the one that it is looking for when I attempted to update the firmware through routerlogin.net.
descriptions or interpretations.------------------------------------------
My apologies for using a bad choice of words.
Again, my apologies that I did not use acceptable terminolgy when trying to explain my issue.
I have even used File Explorers Extract all feature and that didn't even work.
I will continue to work at it using the link you provided above.
Thanks for all the suggestions.
