Cleek58
Nov 30, 2022Tutor
firmware update for R7850
every time i try to update firmware thru download genie it never updates. When i download from the website and extract it to try manual update it says wrong file and aborts. what is going on with th...
Cleek58
Dec 01, 2022Tutor
where would i find the older firmware updates? i have been trying to update this unit for 2 years with the same problems. when I had the support from net gear they couldn't even get me updated.
Dec 01, 2022Guru - Experienced User
here:
https://www.netgear.com/support/product/r7850.aspx#download
and then click on +view previous versions.
- Cleek58Dec 01, 2022Tutor
Thanks all went back and installed every other update and it worked now i am up to date
- FURRYe38Dec 01, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - plemansDec 01, 2022Guru - Experienced User
Glad the stepped approach worked. Like I said, an old version could have expanded the partitioning size or something.
