gesper's avatar
gesper
Firmware update for R7900 with Xfinity modem/router
I have an R7900 hardwired to an Xfinity XB6 Modem/Router. The Netgear app won't connect to the R7900 through wifi (I get an error message). If I unplug the modem input, I can get in but can't upgrade ...
  • antinode's avatar
    antinode
    Apr 02, 2019
    > [...] After confirming that the XB6 still showed that the R7900 was
    > connected and the IP address had not changed, [...]
       Is the XB6 reporting its fond memories of the R7900-as-WAP, or are
    those data current?  Restart the XB6, and see if its story changes.
    > [...] Not sure if that means it never rebooted, Is somehow stuck in
    > the reboot, or if the reboot was complete.
       Until you can talk to its management web site, it may not be possible
    to tell.
       If the R7900 is really working (to some extent, at least), I'd cycle
    the power, and see if its condition changes.  Normally, the management
    web site is fairly reliable, but if the settings got scrambled, it might
    die (for no very good reason), but leave other functions operating.
       When that fails, I'd try a settings reset (and manual
    reconfiguration).  Note that a settings reset should restore it to
    normal-router mode, so, at that point, you ought to be able to connect
    to nothing except (power and) a single computer, and reach it with a
    "routerlogin" name.
       When none of that works, the last ditch is the TFTP recovery scheme.
