Pnurk
May 30, 2019Tutor
Firmware update on R7000P fails; Difficulty using TFTP from Mac
Hi all - haven't found the precise issue here, so I'm posting. New router here. Last night on the web UI connected by wifi, I got the notification that a firmware update was available. Thinking t...
- Jun 01, 2019
Success!
Perhaps I was being too rushed previously, but this time I got it to work first try.
I'll post steps below.
TL;TR:
- I used the OSX command line version of TFTP.
- It took about 40 minutes for the firmware to push to the router.
- ping was useful to know that my computer was communicating properly w the router.
- I put the firmware file at the top level of my user home directory (user folder)
- I had no luck w/ the GUI software recommended elsewhere in the forum and officially by netgear. It began the transfer then timed out and failed repeatedly for me and wasted many, many hours.
STEPS
- set computer to static IP in network settings. Lots of helpful instructions here but don't use their instructions for the tftp part on mac.
- turn off wifi, connect computer to router using an ethernet cable, to one of the downstream ports NOT the yellow upstream port. You may need an ethernet adapter if your computer does not have an ethernet port.
- download the firmware. I placed the firmware file (R7000P-V1.3.1.64_10.1.36.chk here) on the root level of my user directory. In the mac finder, you can navigate to this with keyboard shortcut shift-command-H or by picking "home" under the "go" menu.
- open two terminal windows. One is for Ping, one is for TFTP.
- in the first terminal, type "ping 192.168.1.1" and watch responses while booting. Once you have a flashing amber power light, ping should also be steadily responding.
- in the second terminal window, open a TFTP session to the router and once router is booted, begin sending file.
- it's ok to shut off ping by pressing control-c, or closing the ping window.
- if you want to see if data is travelling over the wire, watch the ethernet light on the router. Packets on that wire cause a flash in the light. This will show both ping packets and TFTP packets, so if you want to know your firmware is being sent, turn off ping.
- there is no status or progress info when transmitting. You simply have to wait. Here it took 40 minutes, on a 2012 macbok pro with gigabit ethernet.
- if successful, eventually you will see something like "Sent 48996410 bytes in 2249.1 seconds" in the terminal window.
TERMINAL TRANSCRIPT OF TFTP SESSION
mbp:~ ear$ mbp:~ ear$ tftp 192.168.1.1 tftp> binary tftp> put R7000P-V1.3.1.64_10.1.36.chk Sent 48996410 bytes in 2249.1 seconds tftp> quit mbp:~ ear$
the command "tftp 192.168.1.1" creates the connection.
the command "binary" causes it to use binary mode
the command "put R7000P-V1.3.1.64_10.1.36.chk" begins transmitting the firmware
****if you see no response, it's probably working****
to be sure data is being sent, look for flashing on the router's ethernet status light.
TERMINAL TRANSCRIPT FOR PING WINDOWN
Last login: Fri May 31 18:08:23 on ttys000 mbp:~ ear$ ping 192.168.1.1 PING 192.168.1.1 (192.168.1.1): 56 data bytes Request timeout for icmp_seq 0 Request timeout for icmp_seq 1 Request timeout for icmp_seq 2 Request timeout for icmp_seq 3 64 bytes from 192.168.1.1: icmp_seq=0 ttl=100 time=4477.386 ms 64 bytes from 192.168.1.1: icmp_seq=1 ttl=100 time=3473.919 ms 64 bytes from 192.168.1.1: icmp_seq=5 ttl=100 time=1.665 ms 64 bytes from 192.168.1.1: icmp_seq=6 ttl=100 time=1.662 ms 64 bytes from 192.168.1.1: icmp_seq=7 ttl=100 time=1.676 ms 64 bytes from 192.168.1.1: icmp_seq=8 ttl=100 time=1.664 ms Request timeout for icmp_seq 10 Request timeout for icmp_seq 11 Request timeout for icmp_seq 12 Request timeout for icmp_seq 13 Request timeout for icmp_seq 14 Request timeout for icmp_seq 15 Request timeout for icmp_seq 16 Request timeout for icmp_seq 17 Request timeout for icmp_seq 18 Request timeout for icmp_seq 19 Request timeout for icmp_seq 20 Request timeout for icmp_seq 21 Request timeout for icmp_seq 22 Request timeout for icmp_seq 23 64 bytes from 192.168.1.1: icmp_seq=24 ttl=100 time=4.522 ms 64 bytes from 192.168.1.1: icmp_seq=25 ttl=100 time=1.690 ms 64 bytes from 192.168.1.1: icmp_seq=26 ttl=100 time=1.653 ms 64 bytes from 192.168.1.1: icmp_seq=27 ttl=100 time=2.079 ms 64 bytes from 192.168.1.1: icmp_seq=28 ttl=100 time=1.679 ms 64 bytes from 192.168.1.1: icmp_seq=29 ttl=100 time=1.653 ms 64 bytes from 192.168.1.1: icmp_seq=30 ttl=100 time=1.686 ms 64 bytes from 192.168.1.1: icmp_seq=31 ttl=100 time=1.612 ms 64 bytes from 192.168.1.1: icmp_seq=32 ttl=100 time=1.643 ms 64 bytes from 192.168.1.1: icmp_seq=33 ttl=100 time=2.083 ms 64 bytes from 192.168.1.1: icmp_seq=34 ttl=100 time=1.635 ms
...etc
shadowsports
May 30, 2019Hero
In most cases, timing plays the biggest role along with proper execution. It sounds like you are very close.
Open two terminal windows. Set one to ping the gateway continiously. Now restart your router and watch the replies.
There is only a 1-3 sec period where the router is "listening" and will accept the FW during start up. If you miss it, no amount of tries or waiting will work.
Once you feel confident about the timing... Set the other terminal prompt up with the command.
Now restart the router and when the 1st window shows a reply, switch to the other window poised with the command and press enter.
Remember, it all comes down to timing.
