bill7x
Jan 11, 2019Tutor
Firmware update on R7000P fails
I am trying to update my firmware on my R7000P from firmware 1.3.1.26 to 1.3.1.44_10.1.23 using the Nighthawk Netgear app on my iPhone 7. I go through thre process and the app says it's successfully ...
- Jan 11, 2019
Don't use Apps to update something critical and sensitive as the router firmware. Use a wired PC and go to http://192.168.1.1 then update the firmware in Advanced -> Administration
bill7x
Jan 11, 2019Tutor
one thing I've noticed is that the router does not appear to actually reboot during the process. The apps says "rebooting your router," but the router lights remain on in the usual way and internet connection continues during this "reboot," suggesting it's not rebooting.
- microchip8Jan 11, 2019Master
- bill7xJan 11, 2019Tutor
Thank you for the suggestion.
If updating firmware via the app is a bad practice, as you contend, then why tf does Netgear suggest it?- myerswJan 11, 2019Master
If updating firmware via the app is a bad practice, as you contend, then why tf does Netgear suggest it?There are a growing number of folks that are mobile devices only so the app.
I agree with above that the only sure way to not have update problems is to access via a Ethernet attached PC to do updates, preferly manually where they firmware has been downloaded. Too many things seem to happen when wireless is used and even more issues come up when the app on say a phone is used.
