CyberCipher
Jul 31, 2021Aspirant
Firmware update to version V1.0.11.126_10.2.112
Updated the R7000 firmware on July 30, 2021. Serious flaws found in this new firmware thus far: 1) the router indicates that 23 devices are connected, and yet it is only able to list the names and a...
DoctorX
Aug 01, 2021Guide
Interesting, because for me #2 was broken through several versions of R7000 firmware and it was finally fixed by v1.0.11.126_10.2.112.
Also, I've never experienced a miscount of devices as you report in #1.
Did you reset to factory settings after updaing your firmware?
My only remaining issue is that I can't disable the router pin to shut off WPS.
- CyberCipherAug 01, 2021AspirantPrior to the update, the only problem I had with #2 (editing names) was that if the names contained "spaces" (ASCII decimal 32), it would crash the router completely. I had to be careful to use hyphens (it didn't seem to have a problem with those). Now, editing doesn't work at all. And if I want to know what's connected, I have to go to the Advanced/Access Control page.
