perspective
Nov 17, 2020Tutor
Firmware Update v1.0.2.76 Nighthawk r7800, DCHP IP issue
Updated Firmware last night, and lost internet connection. Hours of troubleshooting, then speaking with Frontier FiOS, to come back to the cause: the router. Internet works fine if directly connect...
- Nov 17, 2020
What frontier modem/gateway are you using?
Did you try a factory reset and reinstall of the router? any time there's an issue after a firmware change, a reasonable first step is to factory reset and do a clean install (not from backup). maybe an old setting is causing the issues.
Nov 17, 2020Guru - Experienced User
- perspectiveNov 17, 2020TutorNo gateway, connected directly router.
I have never had to factory reset after a firmware update before... I will try that.- plemansNov 17, 2020Guru - Experienced User
perspective wrote:
No gateway, connected directly router.---you have a gateway. The R7800 doesn't have a fibre connection. So there's some type of gateway there.You usually don't need to factory reset after firmware changes but sometimes it is needed if firmware changes enough or an old setting causes issues
- perspectiveNov 17, 2020TutorYes, you’re correct, I do have a gateway, it’s the Verizon FiOS gateway in the garage where the internet comes into the house. I meant I don’t have a separate modem.
Factory reset of the router fixed the issue, as inconvenient as it is. Thanks!
