GJPL
Dec 02, 2017Aspirant
Firmware update
Rec'd email to update firmware but zip file won't open. Updated 1/11/2017 and 6/26/2017 but unable to now. How do I know what version mine is at this point?
- Dec 02, 2017
Thanks ... I finally remembered the login for the routerlogin section..I was having trouble logging in to that area. Then I was able to search for newest version and update the firmware all right.
TheEther
Dec 02, 2017Guru
Where did you get the zip file? Was it included in the email or did you download it from Netgear?
The version number should be displayed at the top when you log into the router's home page.
- GJPLDec 02, 2017Aspirant
