GJPL
Dec 02, 2017Aspirant
Firmware update
Rec'd email to update firmware but zip file won't open. Updated 1/11/2017 and 6/26/2017 but unable to now. How do I know what version mine is at this point?
- Dec 02, 2017
Thanks ... I finally remembered the login for the routerlogin section..I was having trouble logging in to that area. Then I was able to search for newest version and update the firmware all right.
TheEther
Dec 03, 2017Guru
Looks like their front page is busted. Here is the direct link to the R6220:
https://www.netgear.com/support/product/R6220.aspx
minimeme
Dec 03, 2017Tutor
in response to TheEther
that's the same page i got to but that firmware version is the SAME as what I have installed already
It was Last Updated:07/31/2017 | Article ID: 000045284 according to bottom of page.
- minimemeDec 14, 2017Tutor
here's an e-mail i finally received from netgear about why i received the e-mail about new firmware when my router DOES NOT have a newer firmware:
My name is Sengo. I am contacting you regarding your inquiry about the security vulnerability email that you have received.
This email has been sent to all our Netgear customers as a reminder. We're sorry for the inconvenience. And We're currently working on the fix for this KRACK issue and a new firmware will be released soon. So please stay updated to our support.netgear.com for the new firmware release. Until a firmware fix is available for your product, NETGEAR recommends that you follow these workaround procedures:
For Wireless Routers in Bridge Mode: disable Bridge Mode or power off the bridge router. For more information, see your product’s user manual or one of the following knowledge base articles:- minimemeDec 15, 2017Tutor
yay! received a firmware update today. said it had 1 fix. haven't looked up what that fix is yet though.
edit:
hmm, just says
Bug Fixes:
- Fixes security issues.
