GJPL
Dec 02, 2017Aspirant
Firmware update
Rec'd email to update firmware but zip file won't open. Updated 1/11/2017 and 6/26/2017 but unable to now. How do I know what version mine is at this point?
- Dec 02, 2017
Thanks ... I finally remembered the login for the routerlogin section..I was having trouble logging in to that area. Then I was able to search for newest version and update the firmware all right.
minimeme
Dec 14, 2017Tutor
here's an e-mail i finally received from netgear about why i received the e-mail about new firmware when my router DOES NOT have a newer firmware:
My name is Sengo. I am contacting you regarding your inquiry about the security vulnerability email that you have received.
This email has been sent to all our Netgear customers as a reminder. We're sorry for the inconvenience. And We're currently working on the fix for this KRACK issue and a new firmware will be released soon. So please stay updated to our support.netgear.com for the new firmware release. Until a firmware fix is available for your product, NETGEAR recommends that you follow these workaround procedures:
For Wireless Routers in Bridge Mode: disable Bridge Mode or power off the bridge router. For more information, see your product’s user manual or one of the following knowledge base articles:
minimeme
Dec 15, 2017Tutor
yay! received a firmware update today. said it had 1 fix. haven't looked up what that fix is yet though.
edit:
hmm, just says
Bug Fixes:
- Fixes security issues.
