j3trooper
Dec 28, 2018Guide
Firmware update
I received an email today from Netgear informing me that a firmware update to firmware version: v1.0.1.44 was available for my router.
As the current version was v1.0.1.42 I followed the download ...
- Dec 29, 2018
Yes, that model isn't available in the selection here - not because it's not a Nightawk, much more because it is a DSL router (-> https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers )
Firmware, documentation, .... always head to http://www.netgear.com/support/ and ener the model number, like D7800 ...
Current firmware is here: https://www.netgear.com/support/product/D7800.aspx#download - looks like your D7800 is up2date.
IrvSp
Dec 28, 2018Master
V1.0.1.44 is for many routers, and not for the R7800. There is one for the D7800 though, and v1.0.1.42 is the prior version. Sure you don't have a D7800?
If you do, might be better off post HERE in the proper forum.
antinode
Dec 28, 2018Guru
> [...] downloading the zip file with the update. However this would not
> install as I received an error message that that update was not the
> correct update.
What, exactly, did you downoad? What, exactly, did you try to send
to the router? What, exactly, is your router?
> [...] v1.0.1.44 was available for my router.
> As the current version was v1.0.1.42 [...]
> Model: R7800|Nighthawk X4S AC2600 WiFi Router
Not consistent.
