Jaguar94
Oct 07, 2021Aspirant
Firmware update
Attempting to update firmware using the Nighthawk. However I get a firmware check error message. Any help would be much appreciated. Thank you
Oct 07, 2021Guru - Experienced User
Can you manually download the FW file and apply using a PC and web browser?
Is there a problem on the router or is it working ok?
Jaguar94
No problem with the router. I received an email from Netgear suggesting to download the latest firmware. Do you think it’s unnecessary?
