KamiFu5
Apr 25, 2023Aspirant
Firmware Update
I need help finding a solution for my R8000P Router. I tried everything but it still won't update to latest firmware. I've tried app, the site, hard reset the router, manual updates, still don't work...
Apr 25, 2023Guru - Experienced User
If you're on the .50 firmware, you might try this workaround.
Solved: R8000P V1.4.1.50 Update workaround - NETGEAR Communities
