Markg2's avatar
Markg2
Tutor
May 05, 2016
Firmware updates--check, do, when...?
R7300DST   Do you need to know your current version and then check periodically or is there some way to be automatically notified of an update to your date and model router?   How do you know whe...
  • Retired_Member's avatar
    Retired_Member
    May 05, 2016
    When you log into the router it will show you when a update is available. If all is working fine then leave it be. Unless you have time and are knowledgeable enough to undo the update.
    Many recent updates from NG add some option and end up breaking several others.
